Power steering V8 vs 300TDI steering pumps and shift levers
Glen B
Learner Driver
#1 Post by Glen B » Sun Apr 18, 2010 8:56 pm
Hi Guys,
I'm having a problem with my power steering pump. I've bled it and done the steering wheel side to side up on jacks, engine up to temp and running at various speeds for about 5 minutes. Plumbing looks good and there are no leaks or kinks. But still it squeals like mad at any thing over 1000rpm and there is no assisted steering when the wheels are on the ground, all strong arm at the moment.
What I want to know is does the 300tdi run in the same direction and is the plumping the same as my old 3.9 power plant?
The 300Tid came with a PAS pump and made the same nasty noises right away when first started. So I swapped it out in 1/2 an hour for the one off the 3.9L, that was fine when I pulled that motor. So by rights it shouldn't be making such a fuss! But now I'm noticing silver in the fluid. Maybe it's old but I'm just seeing it now that the filler screen is out for the process.
So what gives?
And something different.
What's the correct length of the stick on a R380 manual gear box?
This one is about 6" long with a slight zig-zag to come up straight. There's a dimple about 1/2" from the top for maybe a lock thread but the grip doesn't have a bolt. This doesn't sit tall enough to get the hand grip above the plastic center console..So for now I've extended it. But is there a factory solution for extending the lever or is this perhaps a Defender box?
Glen
#2 Post by DaveB » Mon Apr 19, 2010 6:43 am
Hi Glen,
The steering pumps should be identical. I've got the V8 one running with my 200 tdi, and I've loaned a V8 one to guys with Defenders as well.
Not so sure about the shifter, though. Mine was the same with the LT77 – zigzag and dimple, but it had about a 6" extension above the dimple. The dimple is for the set screw on the extension. I think you're missing the extension piece.
Glen B
Learner Driver
#3 Post by Glen B » Mon Apr 19, 2010 8:00 am
Thanks for that Dave.
Now I might have to drain the system and flush to figure out where the silver is coming from.
Good call on the box lever, will have to keep an eye out for the extension and the gaiter that rivets onto the tunnel.
Glen
#4 Post by red90 » Mon Apr 19, 2010 2:15 pm
Not sure if I have this right, but I think this shows the assembly that attaches to the top of the S shaped bit.
http://www.landyspareparts.co.uk/images/DSC00032_X.JPG
Glen B
Learner Driver
#5 Post by Glen B » Tue Apr 20, 2010 12:29 pm
Hi Red90,
that stick looks very long and probably be as tall as the dash radio if installed into a Discovery, for sure it's going to knock the coffee cups out the tray. No? Quick guess I would say that's a series truck lever.
Still having a pain trying to bleed this power steering circuit. Tried with out running the engine last night and swapped the pump that came with the diesel back in. Still no assisted steering.
On a positive, that awful screech had nothing to do with the pump or any other bearings on the front of the motor. It's all serp belt and some shrapnel rubber getting caught up in the grooves. So a fresh belt from Rover Tech sorted that right out. Thanks Don for your help on this.
Got the Tunnel riveted back in last night with a custom gaiter seal around the base of the shifter, so now no more hole to loose tools through :)
Any one know where to tap the signal to feed the Tac now that I've lost the Coil signal?
Glen
#6 Post by red90 » Tue Apr 20, 2010 3:24 pm
Sorry, that is the Defender stick. I thought we were talking about a Defender. The Disco has the same sort of thing, just a different size.
Without really looking it up, maybe this one... http://www.lrseries.com/shop/product/li ... ver&page=4
http://www.lrseries.com/resources/user/ ... ECTION.jpg
#7 Post by red90 » Tue Apr 20, 2010 3:26 pm
Glen B wrote: Any one know where to tap the signal to feed the Tac now that I've lost the Coil signal?
Look for a terminal labeled "W". If you do not have one, you need to attach to any of the raw feeds before the rectifier.
Glen B
Learner Driver
#8 Post by Glen B » Tue Apr 20, 2010 4:04 pm
Thanks red90,
now we're cooking. I'll sort that alternator out tonight. Just got to bust in under the glovebox again to get at that bundle of spaghetti again.
Anyone have this stick extension that they won't be using?
Glen
Glen B
Learner Driver
#9 Post by Glen B » Wed Apr 21, 2010 12:31 pm
Hi,
So the Tac working like a charm. It's the Grey with white stripe off the original V8 harness that also went to the Alt. The temp sender is hooked up as well, Green with blue stripe, same same. So that is nice to see them working again.
But now the front power windows have defaulted into wind down mode, and won't come back up under their own power. Fuses are good, relay under the glove box clicks as it should, ground is there Hmmm... Might be a pinch some where that I haven't found.
Had to jimmy the leads with 12volts to get them wound up for the rain today, but this is a pain. The rear 2 seem to be fine up and down no problem.
Very odd to me was the 4x flashers went off while I was in there and the only way to clear them was to turn the ignition off,(had been on while testing wires) key out take a breath and then it stopped until about 5min late it started doing it again.
Still no luck with the power steering. :?
Glen
#10 Post by red90 » Wed Apr 21, 2010 1:37 pm
Have you set of the impact sensor or whatever it is called? Perhaps that turns on the flashers and lowers the windows????
Glen B
Learner Driver
#11 Post by Glen B » Wed Apr 21, 2010 2:40 pm
You thinking of the inertia switch on the engine side of the firewall?
I'll check it out, might well be.
#12 Post by red90 » Wed Apr 21, 2010 2:55 pm
Yah, inertia, that is the word.... :lol:
In the olden days, it just shut off the fuel pump, but not sure if things got fancier. Heck, I don't even know what truck you own....
Glen B
Learner Driver
#13 Post by Glen B » Wed Apr 21, 2010 2:59 pm
Sorry red90,
I should have mentioned it way sooner.
She's a 1995 Disco 1, with Lt230 transfer, now sporting a new rebuilt 1997 300TDI, with a 1999 R380 stick box.
Glen
#14 Post by DaveB » Wed Apr 21, 2010 3:17 pm
red90 wrote:Sorry, that is the Defender stick. I thought we were talking about a Defender. The Disco has the same sort of thing, just a different size.
That's definitely appears to be what you're after. It's much the same as the one I have on my LT77.
Glen B
Learner Driver
#15 Post by Glen B » Wed Apr 21, 2010 6:44 pm
Yeah that should do the trick. I just ordered from those guys Red linked to above this afternoon. Should be here next week.
