I am looking to pick up some chain for recovery.
Now if you have a 10,000 lb winch, you should have chain with a 10,000 lb working load limit, Right?
What grade & size of chain are people generally using?
Cheers, Roger
Recovery Chain
chilliwack
chain
I was going to get some chain so I can use the jackall to climb the chain.
I guess I only need chain as strong as the jack. I was thinking about getting stronger chain so I can use it with a winch when I get it.
I am amazed by how strong the synthetics are compared to good ol' chain
Maybe I should just get enough chain to climb the jack on and stick with synthetics for the rest
