e brake
m_kenton
Wet and Wild
e brake
#1 Post by m_kenton » Sun Apr 11, 2010 8:31 pm
I changed the frame on my 2a...the mount for the e brake was welded to the frame which was foolishly decarded. the new frame is an older 2 frame where the mount is bolted on. I have found a bolt on mount however when it installed appears to be too high....and kinks the rod from the brake drum.
Are there different bolt on mounts ie one for a 109 and another for an 88?
It seems as though there should be a bolt on mount that hangs below the frame rail?
Marc
Hand brake
#2 Post by ANDYD » Mon Apr 12, 2010 12:05 am
Hi Marc,
I have found that the LHD and RHD have a lot of different parts and linkages. When I was trying to complete my series hand brake assembly I found out the hard way that a lot of the parts are not compatable!
May not be your problem but i thought I would mention it...
cheers,
m_kenton
Wet and Wild
e brake
#3 Post by m_kenton » Mon Apr 12, 2010 8:26 am
Hi
Thanks but this part came off of a lhd
Marc
