Diesel swap OM617 into a Disco.
franko
http://i302.photobucket.com/albums/nn87 ... G_7981.jpg
http://i302.photobucket.com/albums/nn87 ... G_7980.jpg
http://i302.photobucket.com/albums/nn87 ... G_7979.jpg
http://i302.photobucket.com/albums/nn87 ... G_7978.jpg
Most everthing is clearing alright, might need to trim the valve cover or the cowl so that the valve cover can come on and off.
franko
What, are you guys all snoozing? Must be a bunch of old farts around here.
No comments at all.
Anyway got most of the motor mounts down.
http://i302.photobucket.com/albums/nn87 ... G_8068.jpg
http://i302.photobucket.com/albums/nn87 ... G_8073.jpg
http://i302.photobucket.com/albums/nn87 ... G_8070.jpg
http://i302.photobucket.com/albums/nn87 ... G_8069.jpg
And you can see in the picture below one of the cuts to the oil pan to clear the steering box.
http://i302.photobucket.com/albums/nn87 ... G_8074.jpg
No comments at all.
PaulC
franko
Dreslerdisco
Go frank Go!!!!.
dude
your truck is rad. I am so glad we have time to disco soon. you into party? maybe some logging roads? some camping.
get it done!
get it done!
franko
Thanks Scott, you will have to come out with me on its first test drive.
Well its starting to come together a lot faster these days.
Got the pan all modified so now I have enough clearance for the diff and all.
http://i302.photobucket.com/albums/nn87 ... G_8087.jpg
http://i302.photobucket.com/albums/nn87 ... G_8088.jpg
Closed up the gap on the bell housing, welded a chuck on to it.
http://i302.photobucket.com/albums/nn87 ... G_8090.jpg
http://i302.photobucket.com/albums/nn87 ... G_8091.jpg
And here is what the pan looks like.
http://i302.photobucket.com/albums/nn87 ... G_8094.jpg
http://i302.photobucket.com/albums/nn87 ... G_8098.jpg
Dreslerdisco
Weirdedst thing happened.
So I have to put a new gasket on my oil pan... leaks a bit. I was poking around down there and I brushed my hand against something and all of the sudden I was doused with about three or four cups of water... I was soaked by my truck. I am thinking it was some kind of air conditioning drain nipple... so I checked for another one on the other side... soaked. At least I didn't have my mouth open.
romayama
- Grease Monkey
Discovery Diesel Isuzu 4JB1T conversion
Hello,
I've always been curious about those MB engines fit into Discos. Did you manage to get it driving? How is the power of it?
Here are some pictures of my on-going Isuzu 2.8 turbo diesel conversion:
http://design-engine.ca
My engine is running poor so I'm going to rebuild it soon.
Regards,
Roman
Regards,
Roman
franko
rezdiver
- Master Cylinder
franko
So did you ever make it by the shop? Its still a work in progress,but Its coming along for sure little bit at a time. Chester also is building a house so that takes up some of his time for sure.
How did yours work out,do you like the 1.9 VW swap? Oh and if you still have those wheel spacer I may still take them.
Doc Tari
rezdiver
- Master Cylinder
Franko,
Unfortunately the spacers sold a few days ago.
I never made it to the shop yet, not enough time in a day, gonna go soon, i have not chatted with Chester for a while.
the swap is good so far, lost a bit of top speed but i still have not changed any gearing, i think i will change out 4th gear if i can find a matching old tranny from an old audi 4000 or a porsche 924.
she has way more power than before and i dont need to go fast anyways. she is happy between 90 and 95 on the highway.
working on veggie oil conversion as we speak.
will post up some pics on a new thread so i dont clog up Frankos build.
franko
TEASER VID.
So before I can even get it moving I run into this issue.
The trans will not go into gear; the t-case is in gear and I can feel the trans grab very slightly when shifted into forward or reverse but it's not fully engaging. There is ATF in it. I don't think it's a transmission shifter or linkage adjustment issue because I can slowly move it through the gears and it doesn't ever seem to fully engage. It does not engage enough to ever move the truck; only enough to barely bump it ahead or back. This could be a dirty trans filter causing the pump to not get enough oil or maybe something else. It is not likely electrical.
Anything that you guys can think of that we have not done or forgotten to do. Hoping that rezdiver has my answer and can swing over and get it moving lol.
romayama
- Grease Monkey
Transmission issue
Could not figure out the PM reply, sorry.
I'm having exactly the same transmission issue with my conversion to Isuzu 4JB1T. It started howling at idle and ended up not catching the gear at all.
http://design-engine.ca/vehicles/Diesel/
http://design-engine.ca/vehicles/Diesel/Rebuild/
Also working on dual tank WVO conversion. Can share the drawings for custom under body tanks (2 x 25L).
I also bought a used tranny and currently contemplating a swap.
I, however, suspect one thing that could have caused the trouble: Drive plate to Torque convertor gap - is yours same as it use to be with gas guzzler? If incorrect, this may have destroyed torque converter.
I bought an ATF pressure gauge off ebay for $46 and going to run a pressure line test prior to doing a transmission swap. There is also a tap for Torque converter pressure check, i just have to figure out which one of two.
franko
Re: Diesel swap OM617 into a Disco.
Just a short teaser vid,she runs drives and shifts smooth.. More updates to come.
http://i302.photobucket.com/albums/nn87/franko_6962/th_IMG_1462.jpg
franko
Here are some updates,have been driving the truck for a couple months.
And so far the biggest down side is the stupid water LEAKS,I hate land rovers for that lol.
http://i302.photobucket.com/albums/nn87 ... G_1603.jpg
http://i302.photobucket.com/albums/nn87 ... G_1693.jpg
http://i302.photobucket.com/albums/nn87 ... G_1694.jpg
http://i302.photobucket.com/albums/nn87 ... G_1695.jpg
Oh and its time to change out that dam coupling that landrover thoughtt was such a good idea.
http://i302.photobucket.com/albums/nn87 ... G_1697.jpg
http://i302.photobucket.com/albums/nn87 ... G_1699.jpg
http://i302.photobucket.com/albums/nn87 ... G_1698.jpg
Also was having a hard time starting it in the morning,so i traced it down to a few dead glow plugs.
They are pretty cheap for the om617 so i just decided to replace all 5 of them well i was doing it.
Old glow plugs.
http://i302.photobucket.com/albums/nn87 ... hoto-3.jpg
And new plugs.
http://i302.photobucket.com/albums/nn87 ... hoto-1.jpg
http://i302.photobucket.com/albums/nn87 ... hoto-2.jpg
This one against the firewall was a pain to remove,but i got it out.
http://i302.photobucket.com/albums/nn87 ... /photo.jpg
Old glow plugs.
And new plugs.
franko
Oh and do any of you,have any tips on to how to deal with this mess? :evil:
http://i302.photobucket.com/albums/nn87 ... G_1596.jpg
http://i302.photobucket.com/albums/nn87 ... G_1595.jpg
Does anyone locally stock the boot floor replacing kit?
