LR3 engine removal
Tread Gently
LR3 engine removal
#1 Post by swamijake » Mon Nov 05, 2018 12:31 pm
I've done a bad thing. I bought an LR3 with a blown v6.
I'm going to dive into it this weekend. Any tips on pulling the engine? I do have a 2 post hoist so if pulling the body off is really the only way, it is an option.
Tony4921
Bumper Sticker
Re: LR3 engine removal
#2 Post by Tony4921 » Mon Nov 05, 2018 5:17 pm
I have pulled a 4.4L V8 without removing the body, so a V6 should certainly be possible. They are fairly difficult to get at the bell housing bolts, but take your time, leave the A/C and P/S lines connected and leave the pumps in the engine bay. Much cleaner and easier to get back up and running. Are you putting in another engine or rebuilding the original?
Tread Gently
#3 Post by swamijake » Mon Nov 05, 2018 8:51 pm
Not sure at this point. The previous owner seemed to think a rod had let go, which doesn't make any sense to me.
Plan right now is get it out, pull the pan, and have a look. If it's rebuild-able I'll do that. If not I'll get a long block from an Explorer and rebuild that.
Anything I need to look out for taking the front end apart?
Tony4921
Bumper Sticker
#4 Post by Tony4921 » Tue Nov 06, 2018 5:38 pm
Hi, never stripped one before, but as you said its just a Ford SOHC. Seem to remember that they have a weird 3 timing chain system, with no keyways, just taper gears. So special tool time. Plenty around though, so lots of resources and advice. Good luck.
User avatar
rayhyland
Missing Link
#5 Post by rayhyland » Sat Dec 15, 2018 8:30 pm
I replaced one of those engines in my Explorer as just changing the timing belt required multiple expensive tools. PITA. How hard would it be to import the appropriate aged Diesel engine from Europe?
Ray Hyland
BCOverlandRally.com, NWOverlandRally.com
I drive a 113 (a 110 and three Series 1s)
Tread Gently
#6 Post by swamijake » Wed Dec 19, 2018 8:16 am
Oh no, Ray if I'd known you'd worked on this engine I would have hit you up for pointers! As it is the engine is rebuilt, back in and running. Now I just need to figure out the suspension, hill descent control and brake errors.
I thought about a diesel swap, but the engine's computer is so integrated with everything else I'd be better off getting a whole vehicle.
User avatar
rayhyland
Missing Link
#7 Post by rayhyland » Wed Dec 19, 2018 10:48 am
Yeah that’s kind of what I figured. I was actually looking at bringing in a diesel of that era from France before I ended up with the RRC.
Ray Hyland
