The Rover-Landers of BC
Forum for Land Rover enthusiasts
It is currently Sun Feb 25, 2018 9:32 am
----- Paid Advertisement -----
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: Sat Oct 28, 2017 8:52 am
Offline
Beyond Recovery
User avatar
I have a tdi disco 1
I get a lot of exhaust smell in the cabin - when I am driving down hill
Has anyone had this issue or is there an thread on this topic
Is there a modification to the tail pipe that might help this issue?
And on that note has anyone run across a particulate filter for the exhaust that can be retrofit to the 300 tdi exhaust that does not kill the 'proformance' of the engine
Thank for any advice on this issue
_________________
was -90 RRC 5spd 300 TDI
Now disco 1 5 spd 300 TDI
thx P and D
Top
 Profile
PostPosted: Sat Oct 28, 2017 10:34 am
Offline
Specialist
Which engine? Is it a stock truck or converted?
I would first look for exhaust leaks in the engine bay.
There is no way to install a DPF. You need a computer controlled engine with integral control of the DPF. If you feel smoke levels are high, you can adjust the settings on the injection pump.
Top
 Profile
PostPosted: Thu Nov 02, 2017 1:31 pm
Offline
Half Shaft
Does it smoke blue when going downhill rather than just a diesel exhaust aroma?
Could be valve seals dried out and cracked.
Eric.
Top
 Profile
PostPosted: Fri Nov 03, 2017 12:53 pm
Offline
Born Free
That's not quite true about DPFs. There are several companies that make retrofit DPFs but they are all focused on the heavy duty market. Here are a few:
http://www.dcl-inc.com/products/diesel- ... -retrofit/
http://www.jmdpf.com/diesel-particulate ... on-matthey
http://www.hjs.com/aftermarket/products ... lters.html
The question would be why do you want to? I have a 300tdi and only ever see a slight amount of smoke when on a hill and have the throttle pegged. If you are smoking regularly there is something wrong with the engine. Off the top of my head it could be injectors, timing, valve seals....
As for smell getting into the cabin, I'd start with checking the exhaust system for leaks. If it is leaking under the car you could get some smell. Other thing to check would be window and door seals at the rear of the truck.
If you want a DPF to make your Disco super clean, it would be possible, but would be very expensive and would cost some power and mileage.
Top
 Profile
PostPosted: Sat Nov 11, 2017 10:02 am
Offline
Beyond Recovery
User avatar
All great thoughts and will follow up on these insight
Just finished a drive to Portland and back - great drive and this issue did not arise
So issue is dealing with slower speeds _ so I’ll check exhaust systems
_________________
thx P and D
Top
 Profile
PostPosted: Sat Nov 11, 2017 7:49 pm
Offline
Swivel Ball
I would have a look at your back door seals.
Top
 Profile
PostPosted: Thu Nov 16, 2017 3:28 pm
Offline
Swivel Ball
User avatar
check the rear floor for rust holes.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
